Not sure what has happened but definitely not had a power cut but now showing connection around 12 mins( allowing time for me to log on and post)....but speed up and noise down since yesterday's post
ADSL Settings
another drop in noise margin due to good stable connection resulting increase in connection speed - still more to go
errors seconds have not reset so are misleading
Even better this morning....not sure what the error seconds mean, what impact that has or why they did not reset bu pleased noise is reucing and speed increasing
Connection Information
ADSL Settings
speed just the same as previous stats and noise margin down slightly but just fluctuations not an actual drop. crc/hec errors not particularly high and shouldn't be affecting your download speed at night error seconds look high but that's due to no resetting when router reset las time
I thought my speed had increased , so had another look.It had been 13.65 with noise levels of 9 for the last couple of weeks , just checked it this morning and it has been reset.
ADSL Settings
noise margin now down to about normal 6db which has given another increase in speed - looking good
Help.....my Broadband speed as all but disappeared.....it has been getting slower and slower all afternoon and now it has almost ground to a halt.It has taken 25 minutes to open this page and be able to type this post.Did the BT Speedtest and got Download 0.56 Upload o.87 and Ping Latency 40.38....then went to hub manager and got the following......the speed btw was Wifi and it was marginally better connecting via ethernet cable to my Notebook....
ADSL Settings
