Message 91 of 106
Re: Download times abysmal
Not sure what has happened but definitely not had a power cut but now showing connection around 12 mins( allowing time for me to log on and post)....but speed up and noise down since yesterday's post
Line state:Connected
Connection time:0 days, 00:12:53
Downstream:13.65 Mbps
Upstream:1.086 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):9.7 dB / 6.4 dB
Line attenuation (Down/Up):11.1 dB / 5.5 dB
Output power (Down/Up):20.4 dBm / 12.6 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):1 / 9
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):6 / 6
Error Seconds (Local/Remote):12502 / 73500
Message 92 of 106
another drop in noise margin due to good stable connection resulting increase in connection speed - still more to go
errors seconds have not reset so are misleading
Message 93 of 106
Even better this morning....not sure what the error seconds mean, what impact that has or why they did not reset bu pleased noise is reucing and speed increasing
ADSL Line Status
Connection Information
Connection time:1 days, 00:31:04
Upstream:1.086 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):9.2 dB / 6.2 dB
CRC Events (Down/Up):43725 / 892
HEC Events (Down/Up):18089 / 563
Error Seconds (Local/Remote):15303 / 74366
Message 94 of 106
This link explains the errors in more detail http://www.kitz.co.uk/adsl/linestats_errors.htm
Message 95 of 106
speed just the same as previous stats and noise margin down slightly but just fluctuations not an actual drop. crc/hec errors not particularly high and shouldn't be affecting your download speed at night  error seconds look high but that's due to no resetting when router reset las time
Message 96 of 106
I thought my speed had increased , so had another look.It had been 13.65 with noise levels of 9 for the last couple of weeks , just checked it this morning and it has been reset.
ADSL Line Status
Connection time:0 days, 16:03:06
Downstream:15.77 Mbps
Upstream:1.07 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):6.2 dB / 6.2 dB
Output power (Down/Up):20.1 dBm / 12.6 dBm
CRC Events (Down/Up):11359 / 517
HEC Events (Down/Up):13525 / 339
Error Seconds (Local/Remote):108965 / 87047
Message 97 of 106
noise margin now down to about normal 6db which has given another increase in speed - looking good
Message 98 of 106
you may get one further reset to the new 3dB noise margin which will give a further speed increase
Message 99 of 106
Help.....my Broadband speed as all but disappeared.....it has been getting slower and slower all afternoon and now it has almost ground to a halt.It has taken 25 minutes to open this page and be able to type this post.Did the BT Speedtest and got Download 0.56 Upload o.87 and Ping Latency 40.38....then went to hub manager and got the following......the speed btw was Wifi and it was marginally better connecting via ethernet cable to my Notebook....
Connection time:10 days, 14:19:06
Downstream:15.96 Mbps
Upstream:1.086 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):5.7 dB / 6.4 dB
Output power (Down/Up):20.0 dBm / 12.6 dBm
FEC Events (Down/Up):0 / 48810
CRC Events (Down/Up):7557645 / 27949
HEC Events (Down/Up):7659198 / 181327
Error Seconds (Local/Remote):182959 / 32955
Message 100 of 106
just did speedtest and got 0.74 download ...0.88 upload and 37,75 Ping.....but still soooo slow...please help
