Message 11 of 33
Re: Drastic Download/Upload Speed Drop
I just tried to upload one photo to FB taken with iphone.. after 20 mins of waiting I then get an error message.. ONE PHOTO.
I notice now there is a bar that keeps going on and off on the FB page that says 'no internet connection'
This nightmare has been going on for weeks and all along I am paying for broadband which BT claim is 'acceptable'
Message 12 of 33
you cannot delete posts once you have made them
Message 13 of 33
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
do not use the support.bt.com one
Message 14 of 33
are you doing the speedtest using an ethernet cable connecting your computer to the home hub
Message 15 of 33
can you enter your phone number and post results please  remember to delete number before posting  http://dslchecker.bt.com/adsl/adslchecker.welcome
this will show options available to you
Message 16 of 33
Hi thanks for your reply.. I always use a cable and have my wi-fi disabled
Please see all results to all tests I posted here earlier
Message 17 of 33
can't seem to find the results from dslchecker to show options
Message 18 of 33
I have used this speed tester for all the results posted ealier today (the one you posted link for)
The support.bt.com does not work.. here is a screen shot:Screen Shot 2017-02-20 at 16.04.02.png
Message 19 of 33
Is this what you need?
on Exchange TOTNES is served by Cabinet 13Screen Shot 2017-02-20 at 16.10.53.png
Message 20 of 33
can you please now post the results of the further diagnostics part of the test
