Moderator
Moderator
Message 31 of 33
Re: Drastic Download/Upload Speed Drop
@touareg I'm sorry about the problems you're having with your broadband speed, we most certainly can take a look at this for you if you use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Message 32 of 33
Hi. Have you contacted the mods using the link in the post above this one?
Your issue sounds like the noise on the line is intefering with the broadband causing the equipment at the exchange to reduce your speed to something that is the most stable (but also very slow).  Each time you call, and your speed rises again they are resetting the equipment.  this will only be a temporary fix as the exchange will again reduce your speed incrementally until it get a stable speed (and with the noise, this will be very slow...)
You need to report the fault to the phone line to get the noise sorted without mentioning the broadband.
Call BT Technical Helpdesk on 0800 111 4567.  When the automated voice asks for your phone number DO NOT ENTER IT - wait for her to ask if you have a broadband problem.  You will get through to the right place quicker.  Alternativley you can dial 151 for the faults department for phone lines.
Report that you have noise on your line and they will get that sorted.  Once this is done, your broadband speeds should be a whole lot better.
I would be interested to find out how you get one with this.
1. Is hub in the right 'hole'? If you have a '2-hole' socket, put the ADSL cable into the small square hole...
2. Make sure you are connecting to the correct 'SSID' e.g. BTHub6-1234
3. If you 'work from home', use a business line, not a residential line.
Message 33 of 33
I'm sorry this has taken me so long.
I just read my posts and all the replies from this thread after not being here on this forum for so long and I can see I did not send much in the way of thanks to all those who tried to help me and didn't give anyone a thumbs up. I remember I was in a right state with basically no internet.
I did go to infinity and it was a revelation.. suddenly I was getting speeds way faster than I had ever had and uploading videos was taking a fraction of the time. Though I never found any explanation for why the speeds just dropped out of the blue the way they did.
I since moved house and had to take a big hit to my speeds as where I live now I'm getting around 10 download and 3 upload as its a very long way from the nearest cabinet. It's not too bad though.. we have to settle for the best we can get!
Anyway I just wanted to say thanks very much to all those who tried to help.
