I’m having exactly the same issue - today all of a sudden my speed has dropped from 50mb to 1.5mb. Been like it all day. The only other thing I have noticed is that when the speed drops the Wi-Fi signal improves lots
Welcome to this user forum.
I have moved your post to this new thread, so you can get personal help from the community or moderators, so please watch this thread for updates.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
enter your phone number and post results remember to delete number https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
60 | 41.6 | 13.7 | 8.5 | 35 | Available | Available | -- |
58.7 | 37.7 | 13.5 | 7.9 | 32.4 | Available | Available | -- |
330 | 30 | -- | Available | -- |
Up to 2 | -- | 1 to 3 | Available | Available | -- |
Up to 1 | -- | 1 to 3 | Available | Available | -- |
1 | -- | -- | Available | -- | -- |
Available |
U |
27-10-2020 |
N |
N |
Y |
The most basic test for broadband problems is to check you have a dial tone and if so is there any noise on quiet line test. Any chance you could borrow phone to do test
hub stats?
Have done some more testing - phone test was ok. Problem starts as I move away from the router. Prior to when this issue started as I moved away Wi-Fi strength would reduce but speed would remain steady now as I go further away Wi-Fi strength remains strong but speed reduces. Could it be the impact of it moving from 5ghz to 2.5? Have tried different channels on both bands but makes no difference. Sometimes at the hub I get a low speed but I think this seems to fix after I have been stood by the hub for a while.
recently had another issue with the hub where Wi-Fi strength had reduced all of a sudden but this was fixed by a factory reset and has been working fine until yesterday.
BT wholesale speed test is showing 1-2mb when away from hub then 200mb when in close proximity my line speed should be up to 60 mb
You probably have another interfering signal as you move away from the home hub. This will reduce your speed without affecting the strength, as that would be sharing the channel with you, as only on device can use a wireless channel at a time.
Try changing the wireless channel on the home hub.
