imjolly
Message 11 of 29
Re: Faulty BT Home HUB 3.0
you should always have a conenction at the test socket as that is your main connection to BT line.  are there any wires attached to the front of the master faceplate feeding extension sockets?
john46
Message 12 of 29
could you please post the full hubstats as well as that will also give us more information about your connection
Toneloc0_0
Message 13 of 29
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:03:51
Downstream:15.49 Mbps
Upstream:1.125 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):7.8 dB / 6.1 dB
Line attenuation (Down/Up):12.6 dB / 4.5 dB
Output power (Down/Up):20.1 dBm / 12.0 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):7434 / 62
Toneloc0_0
Message 14 of 29
ADSL Line Status
Connection time:0 days, 00:05:42
Upstream:1.125 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):7.7 dB / 6.1 dB
CRC Events (Down/Up):11170 / 62
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):95454 / 167
Error Seconds (Local/Remote):348 / 9
Toneloc0_0
Message 15 of 29
Hi
Is that the hole at the front with the faceplate on?
Toneloc0_0
Message 16 of 29
No other wires are attached to the face plate
imjolly
Message 17 of 29
this is master socket test socket.jpg  are there any wires attached to the detachable front plate which are probably feeding extensions
imjolly
Message 18 of 29
as you have 1 other extenion socket do you know where tyhat get's connection if not from the master socket - master being first socket in your home where bt wires enter from outside
Toneloc0_0
Message 19 of 29
Hi
Yes there is a telephone plugged in with an ASDL filter coming out of it
Toneloc0_0
Message 20 of 29
Hi
Forgot to say
This has never been a problem before with AOL stable line, good speeds.
Why now?
Cheers
