imjolly
Message 21 of 29
Re: Faulty BT Home HUB 3.0
but I would expect the extension socket to be connected to the back of the front plate of the master socket on terminals 2 & 5.  so if not conencted there how is the extension conencted to the phone line?
Toneloc0_0
Message 22 of 29
Hi
When I connect to the test socket i lose BB but keep the phone line-is that normal?
Could the HH be goosed?
imjolly
Message 23 of 29
if the hub works in whatever socket then it must be ok - so looking for another reason
Toneloc0_0
Message 24 of 29
Hi
There is a white wire that comes out of the bottom of the master socket & goes down the back of the skirting board-this might be leading to the extension under the floorboards??
john46
Message 25 of 29
The internal wiring sounds very suspect to me the master socket should be the first socket after the BT line enters the house
imjolly
Message 26 of 29
the white wire must be conencted to the terminals a & b on the back of the master assuming that is the master on not just someone used an nte5 and then runs to extension.  does the extenal wires connect to the master can you see outside?
Toneloc0_0
Message 27 of 29
Toneloc0_0
Message 28 of 29
Hi
The cable comes from the pole to the house, then into the master socket
Cheers
imjolly
Message 29 of 29
so the extension has been wired incorrectly in that instead of conencting to the terminals 2 & 5 on the faceplate it must be (the white wire) conencted to the terminal a & b on the backplate.  if that is the case then your extension must still work when faceplate removed and that test socket inthis instance does not disconnect all your internal wiring
