RogerOrgan
Message 1 of 3
Re: Help please, I am completely confused about how to control my two BT lines/accounts
2 REPLIES 2
DavidM
Moderator
Moderator
Message 2 of 3
Hi @RogerOrgan and welcome.
You've mentioned you have 2 accounts. Are these business lines? Are you having problems viewing your bills or making changes online? If you can give us as much detail as possible I'm sure we'll be able to advise.
Cheers
David
XRaySpeX
Recognised Expert
Message 3 of 3
Are they at the same premises? If so, they should be under the same a/c no & both managed under your MyBT.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
