Ellisos
Message 1 of 2
Re: Home Hub 5 - how do I disable WiFi ?
I have a BT hub 5 but my wireless has stopped working ?
1 REPLY 1
Liam_
Recognised Expert
Message 2 of 2
Hi,
I assume you mean 'enable' the WiFi.  Look here for the manual,
http://bt.custhelp.com/app/answers/detail/a_id/10477/~/user-guides-and-manuals-for-bt-hubs
See pages 6 & 7.
If that doesn't fix things you may have to try a factory reset of the Hub.  Pin/paperclip whatever, in the little hole in the back.
