Message 1 of 9
Re: How do I mark a post as a question?
I ms struggleng to find where to post a question....Pleasehelp. I am using Firefox to access Yahoo mail. When I try to print an email it prints in the smallest siz epossible. Almost unreadable!!! The is no facility on my Epson to change size.  Help
Daveyhart
8 REPLIES 8
Message 2 of 9
Printing Yahoo Mail messages using Firefox
Moved
Message 3 of 9
Re: Printing Yahoo Mail messages using Firefox
Go to options - mail options - general.
At the bottom of the screen there is an option to change the font size. Advanced settings.
Change it to large, or extra large.
If you want more flexibility in handling your e-mail, then an e-mail program will give you more options.
See Thunderbird setup for BT Yahoo e-mail
Newbie
Message 4 of 9
Trying to install CCTV home cameras but I'm being asked for a static IP
How do I get a static IP address to use for my CCTV cameras without having a Static IP address?   Or How do I upgrade my Infinity one account to get a Static IP?
Distinguished Guru
Message 5 of 9
Re: Trying to install CCTV home cameras but I'm being asked for a static IP
You can only get a static IP from BT by using the Business broadband.
toekneem
(EASBF)
Message 6 of 9
hi this link will explain how to set up a static IP on your PC
http://forumhelp.dyndns.info/networking/staticip.html
Message 7 of 9
If you want to access them outside of your network, then take a look at this page.
Port forwarding problems
Newbie
Message 8 of 9
what options, where?
Message 9 of 9
This thread is over four years old. The solution on here may be out of date to your problem.
I would suggest that you start a new thread stating what your problem is along with what devices you are using, what operating system and what browser.
If it is email related you also need to include what email system you are on. Is it BTMail or BTYahoo. If you don't know you can use this link to find out.
http://diagnostics.bt.com/login/?workflow=EmailChecker
