Message 1 of 4
Re: How much broadband does XBox Live use?
how much does xbox come to if your constantly on it every day and i have a max of 40GB overall with three pc 5 portables and one xbox
3 REPLIES 3
Message 2 of 4
and wheres the usage box located
Message 3 of 4
That is impossible to answer without known what you are using each device for, and even then it would only be a guesstimate. If you are doing a lot of gaming and watching video I would suggest that you get an unlimited package. It will soon pay for itself if you end up going over 40Gb every month.
Distinguished Guru
Distinguished Guru
Message 4 of 4
You can get to the usage monitor here.
