it says my username and password are wrong.... i just used them to sign in, successfully i may add. What do i do now,,,,,,,,, I thought i opted out of this **bleep** once
Hi @jaffacake,
I'm sorry you are having problems opting out of BT WiFi. I'll be able to help you with this. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Hi paddy. Would you be able to help me get bt fon removed from my account aswell? The latest firmware has enabled it. I tried opting in and then opting out of bt wifi but it hasn't helped.
Hi @Voden1 and welcome.
Did you get this sorted yet? If not send me over your details and I'll be happy to help. You'll get the contact the moderators link in my profile.
Cheers
David
I have the same problem. The BT-Fon SSID is causing performance issues with my WIFI. There fore I am trying to opt out.
