Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hello John, I'm also experiencing this issue and I came across this thread upon googling. However, I can't seem to find the 'contact the mods' option under your user name??? looking forward to hear from you. Thanks!
Hi Welcome to the community forums
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband
in the call are you connected to the test socket using a new filter
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
if u The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
This test must be done with a wired connection.
http://speedtest.btwholesale.com/
once you have posted the information asked for then the community members can help you more
Thank You
Hi John, thanks for the quick reply.
I have tried quiet line test and there was no noise.
I found the following lines in the hub logs:
00:14:24, 25 Sep. | ( 112.120000) DSL noise margin: 5.90 dB upstream, 3.00 dB downstream |
00:14:22, 25 Sep. | ( 111.010000) DSL line rate: 1172 Kbps upstream, 18688 Kbps downstream |
Hi @hankenstein and thanks for posting.
Your test results confirm a good connection of over 16meg. Are you testing via wireless or cable?
Cheers
David
Hi David,
thanks for the quick reply!
I tested using cable, I also disconnected all wireless devices before carrying out the test.
The results showed 16meg, but whenever I download anything (i.e. games on steam, ubisoft etc) the maximum speed I have ever achieved is 2MB/s (steam download speed is uncapped) 😞
You're confusing mbps with MB/s (megabits with megabytes)
16mbps is equal to 2MB/s.
