Message 1 of 8
Re: IPC6023
Since having our youview box replaced (dead HDD) we are now getting this problem. Customer services give the normal turn the box on and off script.
How can i get this resolved please?
thank you
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
IPC6023 error code
Hi @leigh_73 I have moved you post to create your own thread as the previous thread was solved long ago.
cheers
John
Moderator
Moderator
Message 3 of 8
Re: IPC6023
Hi @leigh_73 sorry you are experiencing the IPC6023 error code.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Message 4 of 8
Re: IPC6023
Thanks, one of the mods has contacted me, all in hand.
Message 5 of 8
Re: IPC6023
If still not solved keep it simple and get BT
to send 2 Mini Connectors
They will do the trick
Message 6 of 8
Re: IPC6023
@TheLen
It is solved, please do not post the same message on multiple threads,  Thanks.
Message 7 of 8
Re: IPC6023
Just trying to help people Keith
Not something BT is known for ...
I have been kept waiting for 8
months before someone woke up and
supplied the Mini Connectors
Nothing else in the extensive script you have worked
Message 8 of 8
Re: IPC6023
This is only a customer to custome help forum. I am just a customer.
