ForestG
Message 1 of 9
Re: Infinity 2 get slower and slower during the day - evening is hopeless
I have the same problem from the cinderford exchange. I should be getting 50/51 mbs but generally start at 33/34 mbs. Have noticed last couple of weeks that in wireless the speed drops horrendously. I actually had a result back of 0.91mbs download the other night. If I do a test in the mornings it's back up to around 33. (Still much less than I thought) as the day goes on it gets lower and lower. I mean less that 5 mbs on fibre? Is it a hub issue or do I need to refresh the channels?
8 REPLIES 8
gg30340
Message 2 of 9
I've moved you onto your own thread so that you get replies relevant to your problem and to avoid confusion with the other posters problems.
Do you have an Openreach modem and what Homehub are you using?
Have you tried a factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 seconds?
Can you run this checker and post back a screen shot of the results
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
http://speedtest.btwholesale.com/
ForestG
Message 3 of 9
Im on a hh5, these are my test results, only getting 14.99 with a max obtainable of 70.99. hope you can help.
ForestG
Message 4 of 9
sorry, i'll try to make those results clearer!
gg30340
Message 5 of 9
My eyes aren't what the used to be. I can't read most of te stats that you have posted. Can you repost the screen prints. If you use the Windows snipping tool and save it then post them it usually makes them a lot clearer.
Sparky225
Message 6 of 9
My Infinity2 as dropped from 40mb during the Day hours 6mb after 7pm tonight.
This happened to me in March, congestion issue i think...Hinckley Exchange..
pippincp
Sage
Message 7 of 9
Are you running the tests over a wired connection?
ForestG
Message 8 of 9
Yes and with all wireless devices switched off.
pippincp
Sage
Message 9 of 9
When are you going to upload the test results so we can read them? You don't need to put them into word, just upload the images.
