Mickeym
Message 1 of 28
Re: Infinity speed drop
Simply not getting what I was told I would get. If you went to the shop for a kilo of potato's, you would expect a kilo not half a kilo. When we complain, we get that old cherry thown in: (it's up too). 52Mb is not 66Mbs in my contract, or the 75Mbs I was getting.
27 REPLIES 27
DavidM
Moderator
Moderator
Message 2 of 28
Hi Mickeym,
Thanks for posting. I've moved this post to start you own thread so we can look into this for you. Can you try running the speed test including the further diagnostics and post the results? Please run the test when connected via cable only. Once we have the details we'll take it from there.
Cheers
David
Mickeym
Message 3 of 28
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 52.68 Mbps
0 Mbps54.23 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 52.68 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-54.23 Mbps .
 Additional Information:
 IP Profile for your line is - 54.23 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 12.41 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 12.41Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Thanks, that would be great.
Mickeym
Message 4 of 28
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068343+NQ33831531
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 20/01/15
4. Board version:BT Hub 5A
5. DSL uptime:10 days, 22:24:55
6. Data rate:20000 / 56025
7. Maximum data rate:20852 / 64403
8. Noise margin:6.1 / 6.3
9. Line attenuation:19.5 / 17.9
10. Signal attenuation:19.4 / 17.8
11. Data sent/received:5.3 GB / 32.5 GB
12. Broadband username:bthomehub@btbroadband.com
Perhaps this might help you also. Regards.
ray_dorset
Distinguished Guru
Message 5 of 28
What cabinet are you connected to - ECI or Huawei?
If not, I'll try again 🙂
Mickeym
Message 6 of 28
Just tells me FTTC Cabinet 13 Wymondham Exchange.
ray_dorset
Distinguished Guru
Message 7 of 28
That's an ECI cab I think.
Mickeym
Message 8 of 28
Hi DavidM, Were you able to make any progress with my problem. Regards.
RobbieMac
Moderator
Moderator
Message 9 of 28
Hi Mickeym,
Thanks for posting back.
Can you enter your telephone number here and check the estimated speed for your line?  Post back the results and remember to remove your telephone number.
Cheers,
Robbie
Mickeym
Message 10 of 28
Exchange Wymondham Norfolk, served by cabinet 13.
FTTC Range A Downstream         Upstream     Low
Clean: High:68.6  Low:50.3          High:20       14.1
FTTC Range B Impacted
Downstream:  High:59.7  Low:33.0   Upstream: High:19.9   Low:8.9
Contract said I would get 66.6MBs downstream.
For my first 8 months was getting  76MBs it's now down to 52MBs.
