RobbieMac
Moderator
Moderator
Message 11 of 28
Re: Infinity speed drop
Hi Mickeym,
Thanks for replying.
I appreciate that it is a considerable speed drop but the speed is currently within parameters for your line.  I'll be happy to take a quick look over your connection from my side just to be sure.
Click on my username and under the "about me" section of my profile you'll see the link to get in touch with us.
Cheers,
Robbie
Mickeym
Message 12 of 28
Any luck with this Robbie.
john46
Message 13 of 28
The mod team will contact you personally as soon as your email reaches the top of their mail queue normally 3/5 working days
Mickeym
Message 14 of 28
I see, so that's how it works. Cheers.
Mickeym
Message 15 of 28
Well, I will now bow out after getting nowhere with my 40 % drop with Infinity 2 download speeds. Very unhappy BT customer.
ray_dorset
Distinguished Guru
Message 16 of 28
Was this an engineer-install or a self-install?
If not, I'll try again 🙂
Mickeym
Message 17 of 28
engineer-install
ray_dorset
Distinguished Guru
Message 18 of 28
Is the modem plugged into the SSFP Infinity master socket like this?
Infinity Master Socket
Mickeym
Message 19 of 28
Yes it is.
Mickeym
Message 20 of 28
Well Guy's, After getting in touch with India for the 15th time I am now told there is a cap on my line, and my speed should increase to what it was when the cap comes off. Perhaps someone can shed some light on this as it's so unbelievable.
Here I am on Infinity 2 unlimited, paying £27 a month, not a large downloader, and I'm caped. You could not make it up.
Who on earth can you trust out there, Really p****d off with BT and India.
