carl
Message 1 of 10
Re: Infinity speeds after 10 days
my speeds have not been what i was told i would beable to get. I was told when bt contacting me on renewing our contract that we would get speeds of between 16mbs -37mbs i have yet to get over 15mbs bt need to sort this out cant tell there customers that they will get gud speeds then not provide them
9 REPLIES 9
lmosley
Message 2 of 10
Have you had an engineer install?
Or did they say we will just upgrade you on x date?
Message 3 of 10
Infinity needs an engineer install in your home are you sure you do not mean you had an upgrade to the up to 20mb service adsl2+ if so then 15mb would be in the correct region of speeds
carl
Message 4 of 10
im on infinity was told id be getting speeds lowest 16mb highest possible 37mb ive yet to get over 15mb poor if this is what infinity is
reme8488
Message 5 of 10
Carl, as been previously asked:  did an engineer come out to install Infinity? Infinity requires an Openreach engineer to install it.  If no engineer came out then you're not on Infinity.   You should have a white Openreach modem which is then connected to your HomeHub 2 if you're on Infinity.
Kind regards... Tom
BT Infinity2:
carl
Message 6 of 10
yes we had an engineer who installed it we have the white box that connects to the hub my upload speed is fine im getting 8.2 as i was told i would get just the download is abit slower to what i was informed i would get
my test results tonight
> Download speedachieved during the test was - 13628 Kbps
 For your connection, the acceptable range of speedsis 16000-38717 Kbps .
 Additional Information:
 IP Profile for your line is -38717 Kbps
lmosley
Message 7 of 10
Are you using a wireless G device by any chance to access the internet?
carl
Message 8 of 10
i dont know im using laptop how do i find out?
lmosley
Message 9 of 10
Thats prob what it is then. Older laptops generally use wireless G (Wireless G is too slow to transfer the full speeds of infinity)
Just to test to see if it is infact that, is it possible to wire the laptop up tempory to the HH just to quickly test the speed via a wire, To see if the wired conenction makes a difference at all? If it does its Wireless G to blame  😉
carl
Message 10 of 10
ok problem now solved speeds now at 35mbSmiley HappySmiley Very Happy
thank you.
