kaybee327
Message 1 of 12
Re: Internet issues....
I see Looks like I need to jump on the bandwagon as another with speed issues. Best effort speed test says up to 21mbps max and download speed 12.1mbps. Which could be much better but reasonable I suppose.
Problem is noticeable particularly when watching video either on one of the news channels or on YouTube video keeps stalling either completely for a minute or so while it buffers  or give a stutter every few seconds. Using AMD Semperon processor 3000+ 2000Ghz so should be OK for streaming video. if I go to a non bt speedtest dowload is around 6-8mbps.
Here are stats first from Router second from BT speed test
Type:    PPPoA
Modulation:    G.992.5 Annex A
Latency type:    Fast
Noise margin (Down/Up):    8.8 dB / 6.0 dB
Line attenuation (Down/Up):    16.6 dB / 8.4 dB
Output power (Down/Up):    16.4 dBm / 12.0 dBm
FEC Events (Down/Up):    0 / 0
CRC Events (Down/Up):    120 / 33
Loss of Framing (Local/Remote):    0 / 0
Loss of Signal (Local/Remote):    0 / 0
Loss of Power (Local/Remote):    0 / 0
HEC Events (Down/Up):    523 / 10
Error Seconds (Local/Remote):    96 / 1
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
    Download  Speed
    12.81 Mbps
0 Mbps    21 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 12.81 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 13.82 Mbps
2. Upstream Test: -provides background information.
    Upload Speed
    0.86 Mbps
0 Mbps    0.83 Mbps
Upload speed achieved during the test was - 0.86Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Noise seems good but ip profile seems low at 13.82 on a 21mbps line. I know I will not get the full 21 but I should get more than 12.9 surely.
Any suggestions please
For mods can profile be increased please
Keith
11 REPLIES 11
imjolly
Message 2 of 12
I move post so you have your own thread
you have missed of your conenction speed and time
your profile is 88.2% of your conenction speed so to get a higher profile you need to increase your connection speed
are you conencted to the test or master socket?  do you have other sockets apart from the master?
kaybee327
Message 3 of 12
Sorry about that - finger trouble.
Connection Information
Line state: Connected
Connection time: 0 days, 03:32:52
Downstream: 15.3 Mbps
Upstream: 1.109 Mbps
Am using master socket with 2 extension one of which has phone via filter
kaybee327
Message 4 of 12
Up time is low because I unplugges the mains (dumbo me again)  By the way master socket is an ADSL V10
imjolly
Message 5 of 12
yours stats look ok apart from the slightly high noise margin at 8.8.  with your attenuation as you say a conenction speed of about 20/21mb would be expected.
if you are not having problems with drops in connection then just stay connected for the 3+ days, repost stats to show stable connection and then contact the mods and get noise margin reset to 6 which should give the speed increase.  profile will immediately follow giving faster download speed
contact mods
can take up to 3 working days for mods to contact you
imjolly
Message 6 of 12
once you get reset to 6db and then can maintain a stable conenction your noise margin may drop down to 3db which will give a bit more speed but only if line is stable with few errors on 6db
kaybee327
Message 7 of 12
Very many thanks for quick reply.
Before my stupidity line had been up forabout 3 months with no dropped sessions so I think line is stable
So will pass to mods anyway to see if it helps
Thanks again
Keith
john46
Message 8 of 12
you must wait 3+days before contacting the mods as they must see a stable connection posted here before they can reset your noise margin
imjolly
Message 9 of 12
if your conenction is as stable as you say then you could contact the mods as it will probably take at least 3 days for them to contact you and by then you could post your router stats with the needed 3+ days connection time
kaybee327
Message 10 of 12
Yes will contact them now.
Speedtest
    Download  Speed
    11.54 Mbps
0 Mbps    21 Mbps
 Download speedachieved during the test was - 11.54 Mbps
    Upload Speed
    0.9 Mbps
0 Mbps    0.83 Mbps
Upload speed achieved during the test was - 0.9Mbps
so download speed has dropped slightly while upload is the same
Router gives
onnection time:1 days, 09:52:52
Data Transmitted/Received (GB):0.1 / 1.5
Broadband username:
Password:
TCP/IP settings
Broadband network IP address:86.176.230.
Default gateway:217.32.143.229
Primary DNS:213.120.234.74
Secondary DNS:213.120.234.26
