I have had to remove BT Virus Protect and re-install it today (after it got stuck in Checking for Updates).
I now have a BT page telling me it is Active, but when I launch it I'm told it's Deactivated.
When I click to Reactivate, I am asked to login to McAfee using a user name of (gobbledygook) at BTNetprotect.co.uk, which I've not seen before. There's no "forgotten password" option.
What can I do?
Hi @EdB9 welcome to the forum and thanks for posting. Sorry that you are getting a message that the Virus Protect is Deactivated. I've had a look through How to remove and reinstall the Virus Protect and wanted to check if you used the removal tool to ensure all traces of it were removed from your device before reinstalling as that might be a possible cause.
cheers
John
John:
Thanks for the prompt reply.
My attempt to use Uninstall failed, possibly because the Check for Updates was still "running" (actually stuck at 25% for two days!). The BT "Fault Adviser" on the phone advised me to use the Removal tool, and after doing that and two Restarts, I was able to install Virus Protect. Then the current problem hit me.
One oddity I noticed was that an old mobile phone was still linked to my (BT) account - I never found out how to remove it - so the Removal tool hasn't cleared everything out.
Cheers,
Ed B
Hi @EdB9, If you haven't tried already I'd recommend running the McAfee Virtual technician tool as it may be able fix this issue for you. Let me know if this helps?
Neil:
I tried to download McAfee Virtual Technician, but nothing happened.
Through a McAfee chat support, I found that the Technician (MVT) has "retired". (A clue in the BT page from your link - supported browsers are only "IE 6.0 or later (not IE 9.0)" and "Firefox 2.0". )
It's now integrated with McAfee software, which must mean I can't get to its replacement because I'm Deactivated!
However, I was given a URL for MVT with a warning that it might not fix issues for BT-Virus protect. I presume I have nothing to lose... Do you agree?
Hi @EdB9, sorry about the delay getting back to you, yeah give it a try and let me know if it helps?
Neil:
I ran it and it found no problems. It presumably doesn't know about BT Virus Protect and so didn't look at my BT Account.
If there is no-one in BT who can look at things from the BT Account side, I'll have to live without BT Virus Protect, and rely on Windows Defender.
Regards, Ed
I have the same "deactivated" message.3 hours on Sunday to bt help lines and nobody said they could help. Remove and reinstall was their suggestion but I did it 5 times with the same outcome. Mcafee loaded but said my software was deactivated. Is there anyone who I can talk to?
regards
Bernard
