Message 1 of 4
Re: Management of Folders in BT eMail
How do I move folders? I seem to have moved a folder from the top level of my email to be a sub-folder of another...and need to move it back...
It doesn't seem to like simple drag and drop..
Any ideas..?
3 REPLIES 3
Message 2 of 4
As far as I am aware the only way to move a folder is to drag and drop and having just tested it it works.
You can only make it a sub folder of your inbox, draft or a sub folder of one of the folders in your "My Folders" section.
Message 3 of 4
Thanks for the response..
but I have managed to move a top level folder under my inbox to be a subfolder of another.
i want to raise it up again and drag and drop doesn’t seem to work..
do I need to drag it back to the inbox label itself?
Message 4 of 4
