jdsmith
Message 1 of 10
Re: Max Atainable rate?
can you determine if you are fastpath or interleaving from HH5 stats?
9 REPLIES 9
smf22
Recognised Expert
Message 2 of 10
No. BT HH5 won't show them.
Regards
jdsmith
Message 3 of 10
So presumably then if all I have is hh5 there is no other way of deterring this other than ringing and asking BT
Message 4 of 10
jdsmith,
The other way is to open cmd and type "ping google.com" and then post the result here and we'll help further. I highly doubt BT will know if you're on fastpath on FTTC being a different DSLAM to ADSL.
smf22
Recognised Expert
Message 5 of 10
Given that interleaving adds latency (see What is interleaving? What are its pros and cons? Can I ask for it to be switched off?), if you monitor latency to an Internet based host using something like ping, you could make a somewhat educated guess as to when it's on. No guarantees though.
This is one of the reasons you see people using third party routers.
Regards
Message 6 of 10
smf22,
Looks like you've crossed post. If the user can also tell us his general location, that will also help us.
devera
Message 7 of 10
@jdsmithNo you can't tell exactly but if you ping let's say bbc.co.uk, and get ~6ms that's either fastpath or G.INP. This isn't always reliable depending how far you are from the server.
If you want to say thanks for a helpful answer click the ratings star on the left-hand side. If the reply answers your question, mark as ’Mark as Accepted Solution’
Message 8 of 10
devera,
I've already posted this information, this is just going to confuse the OP, no offence.
jdsmith
Message 9 of 10
Packets sent = 4 Recieved = 4 Lost = 0
Approx round trip times in ms:
Min: 14ms Max 15ms Average 14ms
devera
Message 10 of 10
@jdsmith seems you have interleaving mate.
