davidmridge61
Expert
Message 11 of 15
Re: Minimum Guaranteed Speed..
Is the minimum guaranteed speed in your Infinity order confirmation e-mail contractually something you can hold BT to? Fairly simple question I thought. Someone replied that you just wait and see what you get (?). I am bailing out, just wanted help.
imjolly
Message 12 of 15
@davidmridge61 wrote:
Well follow th3 thread then!
I have been posting on the tread and I am not sure what your meang
edit. As now replied
you are guaranteed the. Minimum connection speed and if you don't get that that after engineer has checked connection and can't improve speed to minimum then you can cancel with no cancellation charges
XRaySpeX
Recognised Expert
Message 13 of 15
I have & 3 of us don't understand what you are asking. Please elaborate.
But surely not if it is contractually your guaranteed minimum speed.
Not if what? The Guaranteed Minimum Speed given to you by BT is what it says. If your speed drops below that BT will try to fix it & if it can't you would be eligible to leave FoC. It's all in http://bt.custhelp.com/app/answers/detail/a_id/35296/~/your-line-speed-explained .
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
XRaySpeX
Recognised Expert
Message 14 of 15
Of course, if you've just had the quotes from BT & have not yet been connected, you have no option but to wait until you are before you can find out whether you fall below Minimum Guaranteed Speed & can invoke it. Just like any other guarantee you have to use the product before you can know.
gg30340
Message 15 of 15
davidmridge61
I have moved you onto your own thread because other than the title your posts had nothing to do with the thread that you originally posted on.
