Message 1 of 5
Re: Network Issues
Came from Zen to BT (mistake) constant on Zen for a long time at full 80/20, Been on inifnity 2 8 days (same sync)  last few days were bad but today.
http://postimg.org/image/m3ku60in9/
I have a cable line as a backup. that's 70mbps and although it's running about 40 right now it's running better.
@AimeeLW my vivid 200 went down to 10 most evenings, if your area is good you are lucky. Mine is shocking so i downgraded to 50 and got  free upgrade to 70, oh no wait. they did a price increase and never told me. Did I say free? My Bad!
Anyway back to BT - this had better not be sodding congestion or else I wil be leaving stat!
4 REPLIES 4
Message 2 of 5
Re: Network Issues
http://www.speedtest.net/my-result/4851960248
Speechless...
EDIT!
 this is being caused by the frigging wireless on the HH5! As soon as I use an ethernet cable I get full speed. So I am going to swap it out for a Billion 8800NL and use that instead for now.
I speant ages trying to edit this post then the **bleep**ing portal said it was no longer available so stuff it. it's not my wireless anyway my backup cable line runs fine over same wireless
http://pic.nperf.com/r/37120801-DkJ15BDJ.png
Message 3 of 5
Re: Network Issues
have you tried a manual wireless channel change normally solves most problems
Sage
Message 4 of 5
Re: Network Issues
How things quickly change.
From Cable Forum
"Welcome to my hell, and even going back to the package before mine is still poor. It's like they put you onto a different segment and you stay there speed irrelevant.
This is now my saviour. VM is being canned in 24 days for good."
http://www.speedtest.net/my-result/4848210695
Why did you change from Zen?
Message 5 of 5
Re: Network Issues
From Cable Forum
No idea why you linked from cable forum. I have never been on cable forum!
Because I decided to try BT, do I need a valid reason and what's it got to do with you anyway?
also why was this moved? it was a direct reply to someone who now won't get it
