bushboy1
Message 1 of 6
Re: Now tv sport
i connected my now tv box to my tv and watched sport successfully. later ifound out there was interference on my digital tv channels. also i can recieve no digital channels on my you view box. i have disconnected now tv box and retuned both tv and youview to no avail. it says my signal is weak. it was ok before  i used now tv box. aeriel and connections ok
5 REPLIES 5
JohnC2
Moderator
Moderator
Message 2 of 6
Re: Now tv sport
Hi @bushboy1 I have moved your post to the correct area as the previous thread was solved a few years ago. The community members will be along to provide any help they can.
Cheers
John
bushboy1
Message 3 of 6
Re: Now tv sport
ok thanks.
rarmitage124
Recognised Expert
Message 4 of 6
Re: Now tv sport
Have you got 4G in your area as this could be interfering with your box.
Have a look here for more information: https://at800.tv
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
rarmitage124
Recognised Expert
Message 5 of 6
Re: Now tv sport
Also quick question is this the box that is saying this or is it your TV?
siteguru
Expert
Message 6 of 6
Re: Now tv sport
Do you really mean a NowTV box? Or do you mean a Youview box with the NowTV app?
Ian
http://www.siteguru.co.uk/be/ADSL2PlusForDummies.pdf - Having ADSL issues? Then read this PDF
Please don't click the star beside my name - too many stars makes you look like a swot!
