You arent alone, judging by the number of posts here, including my own. Cant even get diagnostic test to work as it errors out on Edge and Chrome.
was btspeedtester done with wired or wireless connection?
are you using the test socket with a filter or do you have an SSFP? have you tried the test socket to see if that improves youe speed?
try quiet line test dial 17070 option 2 should be quiet and best with corded phone
Hi @Mekoa,
Thanks for posting. Can you post another set of speed test reults so we can compare to the original post?
Cheers
David
download speed appears good and consistent with your profile at present
