Leeharg
Message 1 of 6
Re: Port forwarding Hub 6 ip cameras
Hi,
Iam having the same problem accessing my DVR from outside the network. Ive set everything up like i have done before on my talk talk router but its not working :(. iam using a DDNS which is updating and static ip for my DVR which i have set up portforwarding rules to. I have also turned off smart set up and upnp, any ideas?
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Port forwarding Hub 6 ip cameras - thread 2
Is it a BT Home hub 6 you are using, and did you read the information I posted on the other thread?
https://community.bt.com/t5/Connected-Devices-Other/Port-forwarding-Hub-6-ip-cameras/m-p/1678883#M12...
Its best to have your own thread, which is why I have moved your post. Please reply using the modified subject line. Thanks.
Leeharg
Message 3 of 6
Hi Keith,
Thanks for your quick reply.
I am using the HH6 and i have read your previous post. I have manually assigned my DVR the IP address of 192.168.1.10 which i believe is outside the DHCP range and disabled upnp.
Keith_Beddoe
Message 4 of 6
Please can you provide a screenshot of the page I requested?
Also, can you visit https://www.whatismyip.com/ip-address-lookup/ and make a note of your public IP address.
Then go to this page http://192.168.1.254/0000012803/gui/#/broadband/internet
and see if its the same as your broadband IP address.
Check that you have the correct default gateway setting on the DVR, it should be 192.168.1.254, someone else forgot that one.
DNS should also be the same.
If you need to post images, see here.
https://community.bt.com/t5/help/faqpage/faq-category-id/images#images
Leeharg
Message 5 of 6
Hi have sorted it. My gateway on the DVR was set 192.168.1.254 but the USB net work adapter that plugs into the DVR was set to 192.168.1.1 so I changed it to 192 168.1.254 and it works 🙂 thanks for your help.
Keith_Beddoe
Message 6 of 6
It had to be something simple in the end, as I do know that port forwarding works very well on the HH6.
