greateagle
Message 1 of 28
Re: Repeated disconnects, now very slow connection
Hi,
I'm having a similar problem with very slow internet connection. It was working ok up until a few weeks when it became slow without anything having changed on my side. I reported the problem to the call centre who ran through the usual checks on my side and I informed them the modem was plugged into the main socket, that the connection was wired etc. that I'd tried the line with different modems, devices, filters etc all to no avail. I'd unplugged all unused lines, tired the main socket test connection and conducted the quiet noise test (no noise detected). None of which made any difference to the line speed. An engineer was then sent out who informed me that the line was fine (although he confirmed the speed was rubbish) so there had to be a problem at the exchange. The next day the call centre called back to say that they had fixed a problem at the exchange but there was absolutely difference in the connection speed. Since then I have heard nothing more hence why I am trying this community.
Any ideas as to what to try next gratefully received .
BT Wholesale Speed Test
Download Speed (Mbs) : 0.25
Upload Speed (Mbs) : 0.69
Ping Latency (ms) : 42.13
Further diagnostics
 Download speedachieved during the test was - 0.23 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
 IP Profile for your line is - 0.25 Mbps
Upload speed achieved during the test was - 0.71Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
System Up Time 38:56:11
Port    Status    TxPkts    RxPkts    Collisions    Tx B/s    Rx B/s    Up Time
WAN    PPPoA    674843    564999    0    1113    2721    38:29:01
LAN1    100M/Full    2405013    2361106    0    22078    21814    38:55:58
LAN2    100M/Full
LAN3    Link down
LAN4    Link down
WLAN    300M    575425    669287    0    2643    1215    38:55:24
ADSL Link    Downstream    Upstream
Link Rate    288 Kbps    868 Kbps
Line Attenuation    48.0 dB    30.5 dB
Noise Margin    8.3 dB    5.5 dB
27 REPLIES 27
Message 2 of 28
I moved your post to avoid confusion with the previous thread originator
Message 3 of 28
are you connected to test socket now?
were you dropping connection before engineer fixed the line?  did you have numerous resets as you tried different things - routers, filters sockets?
is quiet line test still ok?
greateagle
Message 4 of 28
I'm not connected to the test socket now (or for any length of time) as when I do that my home phone stop working.
I currently have a Netgear ADSL Modem/Router but I have also tried my old BTHomeHub which didn't make any difference. I have also tried different filters on the main socket (again on difference). The quiet line was ok and revealed no noise on the line.
Before the engineer came the line was already dropping. When he came to the house he confirmed that the line iteself was fine but as he too got slow speeds he concluded that the problem must be at the exchange. The help desk later called me to confirm there was a problrm at the exchange which they had fixed. But alas even though they say the fault has been fixed there has been no chance in the speed I receive.
Message 5 of 28
you can connect your Phone and router to the test socket by using a filter you really need to eliminate any possible internal wiring problems
Message 6 of 28
your stats suggest that all the drops and resets in connection you have landed in a banded profile which normally would have a noise margin >15db.  really need a test socket conenction
greateagle
Message 7 of 28
ok I've done as you suggested. How long do I need to leave it in the test socket before I would expect to see any change in the speed?
Message 8 of 28
just leave it there for at least 24 hours then post back your router stats
Message 9 of 28
if it is a banded profile then it will take 3/5 days stable connection 24/7 before banding will release - so no manual resets
greateagle
Message 10 of 28
Hi,
my connection has now been up for 142 hours and 30 mins but there has been no change to the speed I receive at all. Any suggestions as to what to try next ?
Link Rate    283 Kbps    972 Kbps
Line Attenuation    48.0 dB    30.3 dB
Noise Margin    8.6 dB    5.5 dB
