Message 1 of 10
Re: SLOW Broadband speeds... D:<
Do these error seconds look high?  Engineer came Saturday 9 March to address slow download speeds (c 0.5 - 1mbps).  Ran all tests and eventually switched me from fast to interleaved.  Speeds immediately recovered to 5mbps but now back to 1mbps
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 22:59:16
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):7.4 dB / 25.0 dB
Line attenuation (Down/Up):28.6 dB / 15.5 dB
Output power (Down/Up):19.9 dBm / 11.6 dBm
FEC Events (Down/Up):0 / 5
CRC Events (Down/Up):262810 / 2
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):128595 / 2
Error Seconds (Local/Remote):572872 / 160
9 REPLIES 9
Message 2 of 10
could you run the diagnostic part of the BT speedtest and post the results back http://speedtest.btwholesale.com/
Message 3 of 10
errors are high for a connection time of <24hrs
can you run btspeedtester and after first test completes then run diagnostic test and post the results
try quiet line test   dial 17070 option 2  should hear nothing and best with corded phone  if cordless then dull hum normal
Message 4 of 10
Line is quiet on 17070
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.37 Mbps
0 Mbps7.15 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.37 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
Message 5 of 10
the router says interleaved but the high number of crc/hec and error seconds and almost nil fec errors look more like a fast connection.
as you have a good max connection speed I would try 1 reset tomorrow about lunctime and see if that will actually change it to interleaved and reduce the errors
Message 6 of 10
Thanks - the Interleave switch happened about 36 hours ago.  Would it take time to register properly?
Message 7 of 10
I would expect it to change when router reset but with interleaved you should have lots of fec errors and a lot less of the other errors.  if a reset doesn't help then you will need to contact the mods so here is link in case
contact mods
can take up to 3 working days for mods to contact you
Message 8 of 10
Thanks - I'll monitor over the next day or two and see if there is any change.
Message 9 of 10
Still not seeing much of an improvement.  Grateful if mods could look at this.  Will use the link already provided.
 Download speedachieved during the test was - 1.36 Mbps
 Your DSL Connection Rate :7.33 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 6 Mbps
ADSL Line Status
Connection time:6 days, 04:39:14
Downstream:7.156 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):11.2 dB / 24.0 dB
Line attenuation (Down/Up):28.7 dB / 15.0 dB
Output power (Down/Up):19.8 dBm / 12.2 dBm
FEC Events (Down/Up):116632 / 56
CRC Events (Down/Up):0 / 13
HEC Events (Down/Up):0 / 7
Error Seconds (Local/Remote):0 / 10
Message 10 of 10
your download speed is really low so I would contact mods for help
contact mods
