Davies54
Message 1 of 25
Re: Slow Broadband speeds and complaints to BT
it seems this speed problem is common
i too have seen my speed reduce from 48mps to 22mps i noticed pictures and videos were failing to play or show correctly, can BT please explain i was on the phone to the HD in india for over an hour and they were unable to help, the adviser has raised a fault on VOLO53-********* which is untrackable on the MY BT web site so i have no idea if this is still being looked at or resolved or pending in diferent dept's
i pay for the full BT package infinity unlimited i have mobile too and BT vision but the speed test indicates i am only getting less than average Broadband speeds, whet th hell is BT playing to say this is poor is an understatement wasting my life on the phone to India whos half hearted approach to fault finding not even having the ability to be courtious over the phone when responding to a customers problems if its not resolved soon ill have to take my buisness elswere
Paul Davies / Selsey
Tags (1)
24 REPLIES 24
john46
Message 2 of 25
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
DavidM
Moderator
Moderator
Message 3 of 25
Hi @Davies54,
Thanks for posting. If you can give us the details as requested by @john46 I'm sure we'll be able to help.
Cheers
David
Davies54
Message 4 of 25
BT BROADBAND AVAILABILITY CHECKER.pdf
Other info from HUB required not sure what you mean 1-12 in trouble shooting ?
Davies54
Message 5 of 25
Davies54
Message 6 of 25
well i did upload the Broadband availability checker doc but dont appear to be able to see it ?
Davies54
Message 7 of 25
Telephone Number 01243     on Exchange SELSEY is served by Cabinet 6
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
49
35
7.9
6
Available
VDSL Range B (Impacted)
37.8
20
7.5
3.8
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 17.5
15.5 to 20
Available
WBC ADSL 2+ Annex M
Up to 17.5
Up to 1
15.5 to 20
Available
ADSL Max
Up to 8
7 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Davies54
Message 8 of 25
I looked at another speed query and see they posted this This is my HUB details
1. Product name:
BT Home Hub
2. Serial number:+068343+NQ41639821
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 10/07/15
4. Board version:BT Hub 5A
5. WAN:PPP Connected
6. Data sent/received:400.2 MB / 4.6 GB
7. Broadband username:bthomehub@btbroadband.com
8. BT Wi-fi:Yes
9. 2.4 GHz Wireless network/SSID:BTHub5-ZX5C
10. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
11. 2.4 GHz Wireless security:WPA2
12. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
13. 5 GHz Wireless network/SSID:BTHub5-ZX5C
14. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
15. 5 GHz Wireless security:WPA2
16. 5 GHz Wireless channel:Automatic (Smart Wireless)
17. Firewall:Default
18. MAC Address:40:f2:01:10:96:9a
19. Software variant:AA
20. Boot loader:1.0.0
BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204.1.11 | Last updated 10/07/15
pippincp
Message 9 of 25
That's the wrong page from the router. You need to go to troubleshooting/helpdesk/
Within lines 1 - 12 you will see
Data Rate
Maximum Data Rate
Noise Margin
Line Attenuation.
Davies54
Message 10 of 25
That is Troubleshooting / Helpdesk Grrrrrr
