maVen
Message 1 of 14
Re: Slow broadband downstream line speed and noise on line
I wonder if you could help me too, I found this older thread via a goole search.
My broadband has always been about 3Mps, previously with SKY (connect package) but was heavily throttled at peak times so i went to BT, now it seems I'm being throttled at 1Mps permanently.
Can you help me decipher this data and give me pointers as to how to improve my speed back to 3Mps.
thanks.
(BTW 17070 option 2 test passed ok, no noise on line)
13 REPLIES 13
Keith_Beddoe
Message 2 of 14
You should be connecting at about 2976Kbs.
To enable forum members to help you, please could you look at Helping forum members to help you which asks you to do a few checks first, and has some helpful hints.
When you have done that, please post the results here, so members can offer advice. Thank you.
This actually looks like a fixed 1Mb service.
maVen
Message 3 of 14
So frustrating,
FAQ
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
john46
Message 4 of 14
have you tried connecting to the test socket as suggested in Keiths post
Keith_Beddoe
Message 5 of 14
Deleted by poster as no action needed.
Keith_Beddoe
Message 6 of 14
John,
There is plenty of margin, I would say that its been incorrectly commissioned. There is no way we can check this.
john46
Message 7 of 14
deleted no action needed
maVen
Message 8 of 14
I done the ASDL test via the main socket and it was 2.5MB, then I replaced the plate and plugged the router back in and this is now what I get, this is what I'd expect to get, so I'm puzzled but happy, does this data seem ok to you guys ??
    ADSL Line Status
Connection Information
Line state:Connected
Data Transmitted/Received (GB):0.0 / 4.3
Downstream:2.438 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):15.3 dB / 22.0 dB
Line attenuation (Down/Up):58.0 dB / 31.5 dB
Output power (Down/Up):18.3 dBm / 12.2 dBm
FEC Events (Down/Up):5 / 0
CRC Events (Down/Up):0 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 0
Error Seconds (Local/Remote):43 / 19
john46
Message 9 of 14
much better looks like an internal wiring error possible a poor contact from the test socket to the front plate but that connection looks much better and does not need the care teams help now not sure if Keith has any ideas on  what  the problem may have been
Keith_Beddoe
Message 10 of 14
That looks better, so its not a fixed rate service, it was just odd that it was exactly 1MB before.
How long have you been connected to BT Broadband?
Probably just a bad connection. Is it possible to keep your home hub plugged it at the master sockrt location?
