troully
Message 1 of 8
Re: Slow broadband speed think IP profile is stuck
About a month ago (3rd Aug 12) my BT Infinity was "upgraded to go even faster" - however i have not noticed any increase in speed. The current IP Profile is set to 31.82 Mbps - the speedtester reports around 29 Mbps max. Is this to be expected on an upgraded BT infinity service or is there an issue? The reason I suspect a potential problem is that i was away during the upgrade for 3 weeks and the Hub was turned off at the mains.
Download speed achieved during the test was - 29.71 Mbps
 For your connection, the acceptable range of speeds is 12 Mbps-31.82 Mbps .
 Additional Information:
 IP Profile for your line is - 31.82 Mbps
thanks
7 REPLIES 7
Message 2 of 8
what does the infinity speed checker on the BT.com website say you should get
troully
Message 3 of 8
hi - it says:
Message 4 of 8
hi no the check you carried out when you ordered the upgrade at this link http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=34344
troully
Message 5 of 8
ok... the "new speed test beta" at http://www.speedtester.bt.com/beta/speedtest-remote.jsp reports the following right now:
Download speed 31.08
upload 9.33
ping latency 52.75
is this the right tester?
thx
Message 6 of 8
no the link i have just posted please which gives the estimate you would have had when you placed the order
troully
Message 7 of 8
ok - after entering my phone number on that page - it reports:
39.6Mb download
6.5Mb upload
Now
Message 8 of 8
it looks from that you are getting the maximum possible connection speed as the estimate was 39.6 you are actually getting 31.8 there does not appear any thing wrong with your IP Profile
