cashback09
Message 1 of 23
Re: Slow upload speed but download fine.
Hi there
I am experiencing exactly the same problems almost 4mbps downlaod speed and a max of 0.35 mbps upload speed.
im trying to use a Vodafone sure signal connected to my home hub (as we have such poor mobile reception in our village) and whilst I can hear everyone else on my work conference calls, I sound like a robot when I speak and people cant hear me due to the slow upload speed.
I have called the Broadband help team numerous times, had an engineer visit, just installed a BT accelerator as well and that  has made no difference. Everytime I speak with the call centre they are all very polite and tell me they will resolve this - but so far no one has been able too.
My neighbour uses sky and has never had any issues. im using an apple mac and a work pc all of which have all the latest browsers software etc installed
Any other advice anyone can give would be great!
Many thanks
22 REPLIES 22
Message 2 of 23
welcome to the forum
check your upstream in your router and if 448 then your upload is a good as you will get on adslmax
cashback09
Message 3 of 23
thanks for replying so quickly - i did not see how to make it as a new post
how do i check the upstream in my router...?
cashback09
Message 4 of 23
Slow upload speeds - but download is fine
Hi there
I am experiencing the following problems almost 4mbps downlaod speed and a max of 0.35 mbps upload speed.
Many thanks
Message 5 of 23
hi enter 192.168.1.254 into your browser address bar and navigate to broadband then connection and then post the results back here and someone will advise you further
cashback09
Message 6 of 23
hi thanks again - i did that - it shows my home but 3 welcome page but i can't see broadband or connection anywhere...?
Message 7 of 23
need to go to advanced/ broad band/adsl or something like that - don't use HH now
cashback09
Message 8 of 23
and jsut found this
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 01:43:49
Downstream:3.875 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):17.0 dB / 21.0 dB
Line attenuation (Down/Up):33.9 dB / 19.0 dB
Output power (Down/Up):19.5 dBm / 11.9 dBm
FEC Events (Down/Up):66 / 1
CRC Events (Down/Up):3 / 5
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1 / 0
Error Seconds (Local/Remote):769 / 28
Message 9 of 23
that's it
you are on adslmax with upstream of 448 so you are getting max upload for your connection.  only when your exchange is upgraded to 21CN will you be able to get a faster upload speed
cashback09
Message 10 of 23
but my speed test is only saying aroun .30 to .35 mbps - can i get closer to the .448kbps as vodafone says it needs to be over 35 all the time for sure signal to work..?
