Jaimespencer
Message 1 of 4
Re: Smart Hub already dead.
Our smart hub 6 3months old keeps dropping to orange then eventually goes to blue . This is happening every hour sometimes 3 times per hour
3 REPLIES 3
Webby
Message 2 of 4
Buy a decent third party router.
Jaimespencer
Message 3 of 4
Hi I've just sold my tp link router . Naively believing BT had an issue external. My opinion is they have a complete batch of routers that should have failed quality control checks . Just like Talk Talk .
NeilO
Moderator
Moderator
Message 4 of 4
@Jaimespencer the problem you're having sounds like a connection problem with the line rather than a hub issue. Can you post your router stats and we'll take a look.
