weety1
Message 1 of 3
Re: Smart Hub installation problem
Had infinity for 12 months not had very good wifi in next room bt sent new smart hub out when came tried to connect our mobiles to wifi done one but not the other tried connecting firestick in next room but saying no connection told bt will send replacement hub on this one i was told its got wrong firmware, i have lost faith in bt, also on these hub6 is there two lights or one as in pics show 2 but i only had 1 all i want is a decent signal in next room so son can use fire stick/game console please help
2 REPLIES 2
gg30340
Message 2 of 3
Buy a decent third party VDSL Modem/router and throw the BT hubs in the bin. You can get a decent VDSL Modem/router for about £30/£40 and it will be far superior to the one BT supply you.
prinknash
Expert
Message 3 of 3
Getting a third party VDSL modem/router is probably your best bet. An alternative, if you previously used a Home Hub 5 and still have it, would be to go back to using that. You should find it more reliable than the Home Hub 6.
p
