Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
@john46 wrote:
Your connection time is very low have you been restarting your hub if you have please leave it alone given time the DLM will lower your noise margin and your speed will increase it is nothing to do with how long you have been with BT or any other provider
Hi John sorry to jump on the tread, but if the firmware was updated today would that cause the hub to reboot? I only ask as I'm moving to bt next week and have been wondering when I plug the new hub in it might do a firmware update and will it then reboot? Already showing the dlm that I have had one "drop out".
Solved! Go to Solution.
Yes the HH will reboot after a firmware update but one isolated reboot will have no effect as regards DLM.
@pippincp wrote:Yes the HH will reboot after a firmware update but one isolated reboot will have no effect as regards DLM.
Thank you pippincp, hopefully I won't get any more, For some reason I can't give you a star but I would if I could. Thanks again.
Edit.. it might of awarded it now.
