Message 21 of 38
Re: Sudden drop in BB speed
for your attenuation and noise margin your connection speed is rubbish you should be connecting at the maximum speed of 8mb there is something very wrong with the connection as the last set of stats taken with the hub connected to the test socket
Message 22 of 38
That's what I said LOL
Message 23 of 38
great minds think alike i believe it is said LOL
Message 24 of 38
I would mark this as helpful if I understood
a) what it means
b) what can be done about it...
Message 25 of 38
Use the link and contact the mods for help as there is something wrong that you are not going to fix yourself and need an engineer
Message 26 of 38
Last time they sent an engineer it cost £99..and resulted in
no improvements.
Last time I sent a general email they did not reply.
Message 27 of 38
The forum mods are a UKbased team of BT specialists who will take personal ownership of problems and give you a single point of contact they have a good reputation for problem solving
Message 28 of 38
OK I immediately did as suggested. Sent email...using the appropriate form.. etc.
Here we are a few days later....No reply
Broadband speeds
29th June    1.7 Mbps at 9.30 but 220 Kbps at 12.00 midday
1st-2nd July generally around 2.0 Mbps ... which is OK
3rd July (today) currently at 240 kbps....and crawling
Message 29 of 38
mods will contact you but at present it seems to be taking 5/6 working days so you have a bit to go yet
Message 30 of 38
could you please repost latest hub stats to see any changes it will also help the mods when they read through the thread
