leeds_united_afc
Message 1 of 10
Re: Super slow broadband
Hi
Can you help me since Thursday my internet connection has gone mega slow. I was getting speeds of around 4mbps. I am currently using the BT Home Hub 2 I have got my current statistics below. My neighbour is on Talk Talk Broadband and they are pulling 4.5mbps so whats gone wrong with my connection any help much appreciated
  ADSL line status
Connection information
Line stateConnected
Connection time1 day, 3:21:30
Downstream283 Kbps
Upstream888 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)15.1 dB / 6.3 dB
Line attenuation (Down/Up)45.5 dB / 26.3 dB
Output power (Down/Up)0.0 dBm / 12.9 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)6467 / 0
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)0
9 REPLIES 9
Message 2 of 10
You must leave your home hub turned on and connected to your phone line for at least five days, as your speed has been reduced, either because of a fault, or by continually restarting the home hub.
During that time, do not reset or disconnect it, even to do a speed test.
If your download speed has not increased after that time, then return to this thread for assistance.
Thank you
leeds_united_afc
Message 3 of 10
The problem is my hub seems to drop connection at least once or twice & day so I cant do it continues for 5 days
Message 4 of 10
your hubstats show over 1days connection already please just leave everything as it is and post back your hubstats in 3 days time please
leeds_united_afc
Message 5 of 10
Here are my latest stats
ADSL line status
Line stateConnected
Connection time2 days, 3:45:18
Downstream283 Kbps
Upstream888 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)15.2 dB / 6.1 dB
FEC Errors (Down/Up)12242 / 4294967264
Error Seconds (Local)1
Message 6 of 10
just a matter of waiting the 5 days now
leeds_united_afc
Message 7 of 10
Hi had this modem on 5 days now here are the stats & it is still very slow
ADSL Line Status
Connection Information
Line state:Connected
Connection time:5 days, 03:56:28
Downstream:287.1 Kbps
Upstream:888.9 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):12.3 dB / 10.1 dB
Line attenuation (Down/Up):43.4 dB / 26.2 dB
Output power (Down/Up):17.7 dBm / 12.6 dBm
FEC Events (Down/Up):2869 / 14415
CRC Events (Down/Up):0 / 425
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 868
Error Seconds (Local/Remote):0 / 153
Message 8 of 10
Hi
I am sorry to see you are having problems with your BT Service
I suggest you contact the forum mods they should be able to get your noise margin reset  for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
leeds_united_afc
Message 9 of 10
Problem seems to be sorted now thankyou for your help   ADSL Line Status
Connection time:0 days, 22:04:40
Downstream:7.49 Mbps
Upstream:888.9 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.1 dB / 7.5 dB
Line attenuation (Down/Up):43.2 dB / 26.2 dB
Output power (Down/Up):20.1 dBm / 12.6 dBm
FEC Events (Down/Up):185846 / 2228
CRC Events (Down/Up):692 / 104
HEC Events (Down/Up):9340 / 220
Error Seconds (Local/Remote):176 / 267
Message 10 of 10
Glad all is now ok for you happy to help anytime
