ashg_74
Message 1 of 16
Re: Switch From ADSL_G to ADSL 2+
Hi Guys
I would just like to know if by swicting to ADSL 2 is possible and would it improve my speed as i was told it would be 3-7+mbps when signing up but I was told its only 4.5mbps . Please help and how ?
15 REPLIES 15
XRaySpeX
Recognised Expert
Message 2 of 16
Please your full router stats for ADSL-GMT & we can tell if it'll be faster. It often is.
Also what does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
PaddyB
Moderator
Moderator
Message 3 of 16
Hi @ashg_74,
If you post the information as @XRaySpeX, we'll be able to take a look to see if anything can be done to improve your speeds.
PaddyB
ashg_74
Message 4 of 16
Hi guys sorry for the delay in getting back
See details below:
BT BROADBAND AVAILABILITY CHECKER
Telephone Number on Exchange BELGRAVE is served by Cabinet 9
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 4 -- 3 to 5 Available -- -- -- --
ADSL Max Up to 1 -- 1 to 3.5 Available -- -- -- --
WBC Fixed Rate 1 --
Hope to hear from you soon.
Thank you so much
ashg_74
Message 5 of 16
See details below:
Availability Date
Left in Jumper
WBC Fixed Rate 1 -- -- Available -- -- -- --
Other Offerings
Availability Date
ADSL Multicast -- -- -- Available -- -- -- --
Premise environment
Status
Bridge Tap U
VRI --
NTEFaceplate --
Last Test Date 18-01-1970
Thank you so much
XRaySpeX
Recognised Expert
Message 6 of 16
Looks like ADSL2+ would be better for you but the BT Checker is only an estimate often lagging behind reality. Your full router stats would provide a far more accurate indication if you would post them.
ashg_74
Message 7 of 16
Hi thank you for getting back but can you pls advise how i get the router stats ?
Thank you
XRaySpeX
Recognised Expert
Message 8 of 16
I'm not familiar with HHs but you could try 1 of them around http://www.kitz.co.uk/adsl/frogstats.php#72 .
ashg_74
Message 9 of 16
Hub
2. Serial number: +068340+NQ71418512
3. Firmware version: Software version 4.7.5.1.83.8.130.1.32 (Type A) Last updated 30/07/17
4. Board version: BT Hub 4A
5. ADSL uptime: 3 days, 22:18:06
6. Bandwidth: 448 / 3680
7. Data sent/received: 2.0 GB / 10.5 GB
8. Broadband username: bthomehub@btbroadband.com
9. BT Wi-fi: Yes
10. 2.4 GHz Wireless network/SSID: BTHub4-37HG
11. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security: WPA and WPA2
13. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID: BTHub4-37HG
15. 5 GHz Wireless connections: Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security: WPA2
17. 5 GHz Wireless channel: Automatic (Smart Wireless)
18. Firewall: Default
19. MAC Address: f4:6b:ef:08:ce:b4
20. VPI/VCI: 0 / 38
21. Modulation: G.992.1 Annex A
22. Latency type: Fast
23. Software variant: -
24. Boot loader: -
ashg_74
Message 10 of 16
Hi this is the information I coupd get for the router
I hope this helps.
Thank you
