Rottie
Recognised Expert
Message 11 of 13
Re: Unresponsive Internet for 10-20 secons then fine again
@Stuartd wrote:
The same thing happens with the Homehub, just tried it. This has happened before but then gone away. I have ruled out the wifi as the issue by streaming a film from my PC to my Ipad 3 using wifi. There are no disconnects it streams fine so it must be an Internet problem. My area code is not listed as affected on the status page either though, my IP address is also the same sand hasn't changed.
Hi there,
It's likely you've already tried this, but if you haven't already done so, I would suggest that you change your DNS server settings to either Google, or OpenDNS.
I hope this info helps. 😄
Deathtrap3000
Recognised Expert
Message 12 of 13
Seems like my connection has just started doing the same thing. Disconnects on wifi but ethernet remains ok I think.
BuckleZ
Message 13 of 13
Mine does this, ONLY on my MacBook Pro...
I'm geting sent a HomeHub Type B to try.
It only started happening since the firmware upgrade for Type A
