I have the problem of Infinity dropping out constantly - or such a low signal that nothing works properly. I reported it by phone on Friday 27th October 2017. They identified a fault outside my home and said it would take 4 days to fix. It's now over a week and still no improvement. I've done all the tests (when I can get online) - speed when working is 51mb/s. Ha ha! Chance would be a fine thing! Just how long am I supposed to wait? I'm trying to run an online business & paid extra for a supposedly higher grade of broadband! I've just had a forced week off work as I can't connect for long enough to do anything. phone calls to chase it have not helped.
Solved! Go to Solution.
As you run a business do you have a business line?
Not yet, as I'm re-building my website. As I only have 2 items connected to the internet at any time, it shouldn't be necessary. Infinity should cope with it with ease!
Its not a question of Infinity coping with it or not, it is a question of getting a better SLA. Aso running a business is against the terms and conditions of a residential line.
When the internet is fixed - whenever they finally get around to fixing the fault - and when I've finished building my website, I'll look into it. Thanks for the heads-up.
Sorry, Grawlings....I've never used a forum before and have no idea about "threads". I'll go for help someplace else.....take advice & go to customer complaints may well be the answer. Thank you.
Please post your full Router Stats. For a Home Hub see on here: Broadband Top Tips . Full router stats are key to any speed & connection issues.
Try plugging your router into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets? Are there any wires connected to back of faceplate?
Post your full Router Stats when plugged into test socket.
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
