Orbus
Message 1 of 17
Re: Upgraded to Infinity 2 but limited to Infinity 1 speed
Hi there, the exact same thing has happened to me. I upgraded to Infinity 2 but I am restricted to Infinity 1 speeds. Can one of the Moderation team please let me know how I go about resolving this please?
Many thanks.
16 REPLIES 16
Webby
Message 2 of 17
Start your own thread with details from the DSL checker and the connection stats from your router
DavidM
Moderator
Moderator
Message 3 of 17
Hi @Orbus and welcome.
I've moved your post so we can offer some help. Can you please post the details as requested by @Webby and we'll take it from there.
Cheers
David
Orbus
Message 4 of 17
Apologies David as I didn't want to create a new thread when there was one that covered the topic already.
I have ran the Router Stats and the results are as follows:
[code]
1. Product name: BT Home Hub
2. Serial number: +068543+NQ55021573
3. Firmware version: Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 16/07/17
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 09:38:29
6. Data rate: 19978 / 51152
7. Maximum data rate: 22519 / 47641
8. Noise margin: 5.7 / 4.1
9. Line attenuation: 25.7 / 18.4
10. Signal attenuation: 25.7 / 18.2
11. Data sent/received: 228.2 MB / 5.0 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4 GHz Wireless network/SSID: BTHub5-HXKR
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-HXKR
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 84:a4:23:10:5d:7c
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0[/code]
Orbus
Message 5 of 17
VDSL Range A (Clean)74552018.148.9Available----Yes--
VDSL Range B (Impacted)61.235209.827.5Available----Yes--
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 4.5--3 to 7Available------Yes
WBC ADSL 2+ Annex MUp to 4.5Up to 0.53 to 7Available------Yes
ADSL MaxUp to 3.5--2.5 to 6.5Available--------
WBC Fixed Rate1----Available------Yes
Webby
Message 6 of 17
Are you connected to the master socket, or an extension?
Orbus
Message 7 of 17
Hi Webby, the router is plugged into the only socket in the house and from there it is CAT5 network cable to my PC. There are no other issues with my LAN as I can transfer to my local server without any issues, only the internet speed has not changed since upgrading.
Webby
Message 8 of 17
You need an engineer visit.
Orbus
Message 9 of 17
Ever since I have had BT broadband my BT Router speeds (Advanced Settings > Broadband > Connection) have never went above 50Mbps and this is still the same now. I think that it is a provisioning issue rather than one that a tech is needed to come out for.
Webby
Message 10 of 17
You're on 80/20, proven by your upstream connection rate.
For some reason, the line isn't getting close.
Could be an incorrect speed estimation, poor line, thin guage or aluminium cabling etc.
You need an engineer issue to determine the cause of the slow speeds.
