Message 11 of 31
Re: Uploading causes drop
Hi @DumbarSteve  Sorry to hear that uploading was causing your connection to drop.
Did you get this resolved? If not and you are still experiencing this problem we'll be happy to help you get is sorted if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Message 12 of 31
Thanks @JohnC2 . No, no resolution yet.  I have sent the message to Mods as you suggested.
Many Thanks.
Message 13 of 31
Thanks for doing that @DumbarSteve.
I can see your email in our queue so it is there. As soon as we help everyone from the weekend and earlier today we'll get in touch and help you.
DanielS
Message 14 of 31
Thanks for the call.
Just decided to try again and upload a 2.78GB video file to Mediazilla.com
17.4% into the upload the internet connection went down.  Looks like the HH6 just reset itself.
It's infuriating 😞 Never had this with an ISP before.
I can only assume there is some issue at BT's side, or indeed HH6 settings that are causing this issue as it has been suggested that using a third party router may solve it.  TBH I'd rather find a solution to allow the kit I've been given to work on the Infinity4 service rather than essentially going through 'hacks' to try and sort it.  Hope that sounds reasonable.
I'm more than comfortable playing around with the HH6 service menu's if need be, or happy for a tech to remote access and sort it for me.  Even if there's a way of setting an instruction to ignore any traffic management for certain sites (namely vimdeo.com, youtube.com and mediazilla.com).
Cheers
Message 15 of 31
duplicate post - deleted
Message 16 of 31
Update:
Just tried again with another video file to mediazilla.com
1505: started upload
1509: 1Gb (nearly exactly) later the upload stopped.
1510:  Got disconnected status, all traffic stopped.  Waited and waited, still showed broadband disconnected.
1517:  Had to restart HH6 via manager screen.
1522:  HH6 finished reboot, showed connected but no data connected to iMac.  Had to turn off wifi and on again to get data connection.
I have saved the event logs for this period if you would like them sent over.
A 10-15minute gap in service each time this happens.
Message 17 of 31
Slow down the file  upload rate until it stops the problem.
Message 18 of 31
Thanks but rather than simply find a workaround, I'd rather find a full solution to the problem that should NOT be occurring!
Message 19 of 31
The solution is in message3
Message 20 of 31
Once again that is not a SOLUTION, it's simply a WORKAROUND.
BT supply me with an expensive broadband service, and the equipment for me to use it. I don't think it unreasonable to be able to use it to the full potential of what I was sold. ie 300mbps download, and 30Mbps upload.
Nowhere did they say you can get 30mbps upload...BUT... you'll need another router that can limit your upload speeds so that your broadband doesn't repeatedly fail! That is NOT a solution, and if that is genuinely a limitation of the service I have been sold then it is a product not fit for purpose.
I'm still here and looking forward to someone who IS willing to help me find that solution. @JohnC2 is investigating for me and I appreciate that, far more than the latest two comments that simply suggest workarounds.
