AndrewJenkins
Message 1 of 2
Re: Very slow broadband speed <128kbps
Dear John
Have read your posts with interest.
I am suffering v slow broadband (Speedtest.net shows Download 0.13 Upload 0.38)
My Netgear modem stats are below.
BT came and said that noise levels were too high and reset at the exchange, after replacing the box. Nothing improved and they are coming back. Done all the usual tests but nothing works.
Any ideas would be gratefully appreciated.
System Up Time 20:18:59
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANPPPoA2125742716910296285420:18:26
LAN100M/Full2768112519880291249220:18:55
WLAN11M/54M3589145080127420:18:45
ADSL LinkDownstreamUpstream
Connection Speed3840 kbps448 kbps
Line Attenuation40 db11.5 db
Noise Margin9 db24 db
1 REPLY 1
imjolly
Message 2 of 2
as the original post is marked as solved and your problem does not appear the same I have started your own thread where you will get more replies
when is the engineer coming back?  if next day or so then there is no point in making any changes until the engineer has been and hopefully sorted the problem
