yoo_floriana
Message 1 of 24
Re: Very slow broadband speed
i have the same problem for mor then 3 weeks can you help me
My Services
BroadbandConnected
  Disconnect
Broadband usernamebthomehub@btbroadband.com
BT Broadband TalkTelephone number xxxxxxxx088 connected
  Show number
BT FONActive
BT Power SaveNot enabled
  Configure
BT Access ControlNot enabled
  Configure
My Home Network
Devices currently connected to your BT Home Hub.
WirelessUnknown-a0-0b-ba-f0-12-f5
Wirelessflo-PC
EthernetNo devices detected
USBNo devices detected
Telephones0 handset registered
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 4:32:13
Downstream1,696 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)14.9 dB / 13.0 dB
Line attenuation (Down/Up)61.0 dB / 31.5 dB
Output power (Down/Up)17.1 dBm / 12.3 dBm
Loss of Framing (Local)22
Loss of Signal (Local)2
Loss of Power (Local)0
FEC Errors (Down/Up)7294 / 22
CRC Errors (Down/Up)392 / N/A
HEC Errors (Down/Up)N/A / 16
Error Seconds (Local)492
  Hide Details
23 REPLIES 23
Message 2 of 24
Slow broadband speed
Hi i have started your own thread to save confusion in the replies to the other poster
Message 3 of 24
Re: Slow broadband speed
Hi Welcome to the forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
yoo_floriana
Message 4 of 24
thank you for your answer,where should i post all you ask me to do,i am a bit confuse.
Message 5 of 24
post the information asked for here please
yoo_floriana
Message 6 of 24
i have bt hub 2
ADSL line status
Line stateConnected
Connection time0 days, 0:17:16
Downstream1,632 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)15.4 dB / 15.0 dB
Line attenuation (Down/Up)62.0 dB / 31.5 dB
Output power (Down/Up)17.0 dBm / 12.3 dBm
Loss of Framing (Local)12
Loss of Signal (Local)1
FEC Errors (Down/Up)86 / 0
CRC Errors (Down/Up)5 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)428
  Hide Details
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.12 Mbps
0 Mbps0.25 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.12 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
 Additional Information:
 Your DSL Connection Rate :1.63 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.14 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
The quite line test was fine,no noises .I have the first type of master socket ,not that old type.Now i will provide the speed test and adsl statistic with the home hub pluged in to the test socket.
FAQ
 Download  Speed
 0.12 Mbps
0 Mbps0.25 Mbps
ADSL line status
Line stateConnected
Connection time0 days, 0:42:21
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)15.3 dB / 15.0 dB
Loss of Framing (Local)16
FEC Errors (Down/Up)183 / 2
CRC Errors (Down/Up)250 / N/A
Error Seconds (Local)435
  Hide Details
Message 7 of 24
Hi you now need to maintain a stable connection with no hub restarts for at least 5 days and your IP Profile will rise automatically when your hub stats show 5 days + connection time please post back your hub stats and a the speed test and if you need any further help we can organise it for you
yoo_floriana
Message 8 of 24
ok,i will wait 5 days ,do you think it will work like before after that?Do you think the problem is because i did a reset on the  hub?
Message 9 of 24
it may improve earlier than 5 days however The IP Profile sometimes sticks and if it does we can get the Forum Moderators involved and they can do a manual reset for you just post back if you need further help
yoo_floriana
Message 10 of 24
hi again,this morning internet was fast like before and somebody from bt rung me and said it will stay like that ,and at lunch time i had no internet for 5 min and then was working fine again,now is very slow again and is keep droping, i will show you the adsl status,honestly i dont know what to do.
ADSL line status
Line stateConnected
Connection time0 days, 0:02:05
Downstream160 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)21.7 dB / 15.0 dB
Output power (Down/Up)13.1 dBm / 12.3 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
FEC Errors (Down/Up)48 / 0
CRC Errors (Down/Up)0 / N/A
Error Seconds (Local)0
  Hide Details
