Newbie
Message 1 of 3
Re: Very slow internet speed after moving houses
Im having huge problems and bt will not give me any answers besides wait 72 hours. Ive been waiting over 3 weeks now and no change!!! please help...
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+Up to 1--0.25 to 2Available
ADSL MaxUp to 1--0.25 to 2Available
WBC Fixed Rate0.5----Available
Other Offerings
Copper Multicast------Available
2 REPLIES 2
Message 2 of 3
I have moved your post so you can start your own thread to save confusion in replies as your problem is different
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Moderator
Moderator
Message 3 of 3
Hi Miltons,
Welcome and thanks for posting. I'm sure we can help with this. Can you please run the speed test including the further diagnostics and post the results?
Cheers
David
