barryliv
Message 1 of 28
Re: Welcome to rip off BT and slow broadband speed
broadband is really slow 0.06mbps thats slower than some mobile interent!! here are the results from the bt wholesale speed tester and my adshl results 1. Best Effort Test:  -provides background information.
 Download  Speed
 0.06 Mbps
0 Mbps0.25 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.06 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
 Additional Information:
 Your DSL Connection Rate :0.16 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.14 Mbps
ADSL Line Status
Connection Information
Line state:Connected
Connection time:1 days, 07:23:06
Downstream:160 Kbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):29.8 dB / 9.0 dB
Line attenuation (Down/Up):53.4 dB / 30.5 dB
Output power (Down/Up):14.3 dBm / 12.5 dBm
FEC Events (Down/Up):472759 / 25363
CRC Events (Down/Up):4315 / 262
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):4422 / 255
Error Seconds (Local/Remote):
1710 / 250
HELP!!!
27 REPLIES 27
Message 2 of 28
I moved you post to start your own thread so you get more replies
are you connected to master or test socket  if not test can you connect to test socket and repost your stats please
Message 3 of 28
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
barryliv
Message 4 of 28
yes connected to master socket
barryliv
Message 5 of 28
done
Message 6 of 28
you need the test socket not just the master socket what was the result of the quiet line test
Message 7 of 28
your noise margin  is high due to  multiple hub dis connections you now need to be connected to the test socket for the next 3/5 days this will then start to increase your speed the important thing is no hub restarts
barryliv
Message 8 of 28
line was quite when done
barryliv
Message 9 of 28
what is the test socket
Guru
Guru
Message 10 of 28
Hi barryliv,
This is a quick guide to the Test socket:
A) Your Test Socket is found behind your BTNTE5 Master socket / Openreach ADSL Filtered Master Socket.
These master sockets look like the ones below:
Step B - Carefully Remove the removable faceplate of the BTNTE5/Openreach ADSL Filtered Master Socket to Reveal The TEST Socket.
You will then see a test socket (Circled in red in the picture below). Please connect a Different Microfilter (ie different to the one you were already using, Then connect your router to the microfilter and plug into the TEST Socket.
Step C - Repost ADSL Line Statistics
Please repost your ADSL Line statistics which includes Connection Speed, Line Attenuation and Noise Margin and the errors
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
