Martin3366
Message 1 of 3
Re: bt fon & openzone local only or limited connectivity - what's wrong BT?
Hi Kiwigav, I've the same problem and tried all the same 'solutions' without any joy. It's very frustrating and seems quite common. Tried different locations etc., tried using the iphone app with the same router and that doesn't work either. Poor show by BT.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Hi Martin3366,
Thanks for posting. Are you getting any error messages? The iphone might be “remembering” a previous hotspot and once out of range will drop the signal. Have you tried deleting the connection and re-connecting? If you’re still having problems let us know. I’m sure we’ll be able to help.
Cheers
David
spencert
Message 3 of 3
I agree. If possible, it's best to clear all uneeded profile and connect again.
