DavidMk7
Message 1 of 5
Re: can't get more than 2 Mb/s BB speed
My apologies for reviving and hijacking this old post, but it came up on a search and I was struck by the remarkable similarities to my problem in some respects.
I am also stuck on a download limit of 1.8Mb/sec and have been since my contract began. However, the problem is not my IP profile, which shows 13.4.
I have an old style socket, so can’t use the ‘test’ socket, but have connected directly to the main socket, with nothing attached to the extension.
Unfortunately, I don’t have a home hub (actually, I have a really old one, but can't access any statistics), but have used a variety of ADLS2 routers, all of which experience the same problem.  The current router’s stats page does not match the info shown by the home hubs, but I have attached what I can obtain.  I have also attached my speedtest results.
I have contacted BT and they are talking about sending an engineer around, with a potential chanrge of £130, but I wanted to see whether anyone here has any ideas as to why my speedtest shows 13 for my IP profile when my download speed is only 1.8.  It just seems too much of a coincidence to me that I can only download at the same 1.8 that Claudiu was experiencing.  Is there anyway that my profile could be stuck at 2mb but still somehow reporting 13?
System up Time:
0:55:52
Current Date/Time:
CPU Usage:
0.28%
Memory Usage:
78%
WAN Port Statistics
Link Status:
Up
WAN IP Address:
86.151.143.247
Upstream Speed:
828 kbps
Downstream Speed:
15564 kbps
Node-Link
Status
TxPkts
RxPkts
Errors
Tx B/s
Rx B/s
Up Time
1-PPPoA
Up
86190
142101
0
0
0
0:54:29
LAN Port Statistics
Status
TxPkts
RxPkts
Collisions
143219
87692
0
1. Best Effort Test:  -provides background information.
Download  Speed
13.47 Mbps
0 Mbps
21 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 13.47 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 13.73 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.67 Mbps
0 Mbps
0.83 Mbps
Upload speed achieved during the test was - 0.67Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
4 REPLIES 4
Message 2 of 5
I have moved your post to start your own thread and that way there will be no confusion with the previous originator
you are on adsl2/2+ and as such your profile is 88.2% of conenction speed and changes immediately your speed chnages.  from the information you have  posted you have the correct profile for your conenction speed and a good downoad speed for your profile
are you sure you are not confusing bits with bytes?
DavidMk7
Message 3 of 5
Thanks for this imjolly.  And you’re quite right; I’ve been a complete idiot and not been paying attention to the size of the Bs!  Download speeds are in mega-bytes and connection/speedtest figures in mega-bits, so, once you do the maths, everything is actually OK.  I’m quite surprised that none of the tech support people picked up on this.  I’m also seriously embarrassed about making such a novice mistake myself and not to mention a tad disappointed that I won’t now be able to improve my connection speeds.
Message 4 of 5
Its a very common mistake, so you are forgiven Smiley Wink
Message 5 of 5
Don't worry it is a common occurance but looking at your stsa you already have a good connection speed
