Erv65
Message 1 of 13
Re instating bt email address
I have had a g mail update that puts all important emails in the recycle bin. How do i get my BTe mail working again . I think it was stopped a while ago.
12 REPLIES 12
Keith_Beddoe
Message 2 of 13
Re: Re instating bt email address
My Gmail is fine, never had any issues with it at all.  Are you a BT Broadband customer?
Erv65
Message 3 of 13
Yes. I was happy with gmail for years till i got an update that decides for you where to put your emails. I have problem with a group email that goes to several addresses in the group . The new gmail sticks these in recycle and they are the most important mails from a large group of my friends .
Erv65
Message 4 of 13
I think my old BT address was suspended because i never used it . I only used gmail because it used to be great. I am fed up with upgrades that make things more complicated or in this case unusable.
Erv65
Message 5 of 13
For a distinguished sage your reply was far from helpful !!!😀
Keith_Beddoe
Message 6 of 13
I use the Thunderbird e-mail client to deal with Gmail, and BT mail, so all of my mail filtering is done using that.
Have you tried logging ito your old BT e-mail account?
Use this link https://signin1.bt.com/login/emailloginform
If its been deleted, then you will have to login to MyBT, and select the e-mail tile. It should tell you whether you are on the new BT mail, or the old BT Yahoo mail.
Erv65
Message 7 of 13
O.k will try that . Thank you.
Keith_Beddoe
Message 8 of 13
This is only a customer to customer help forum.
If you are not happy with the advice given here, then perhaps you had better contact BT, and ask them about your old e-mail address.
Erv65
Message 9 of 13
Hey i was only joking . Note the smiley face. Sorry if i offended you .
Erv65
Message 10 of 13
Oh the icon doesn't show , sorry.
